Hi PTC,
Please add the ability to Creo Simulate to allow Idealizations like springs, rigid links to be tied to Idealization sets (groups) so they can be turned on and off from the Analysis Definition Dialog box just like Loads and Contacts can be.
This would allow one to work more efficiently in large assemblies while using simplified reps to isolate components and turn on needed constraints and off not needed constraints.
Don Anderson
