When using IFX it is not possible to select inactive surfaces.
For expample the overall assembly of a product contains diffrent variants of subassemblies. Now in the design process we are adding the bolt/nut/washer to one of the variants by activating the subassembly and assembling the bolt. Right now we are using the OOTB functionality of Creo to assemble bolts like this since it is not possible to select inactiv surfaces with IFX.
The provided solution within IFX by setting up an offset for the screw or the surface is ok and seen as a workaround. However the benefit of checking fastener connections automatically as well as placing the bolt/washer/nut on the surface after changing the thickness of the inactive e.g. sheetmetal is not given anymore.
