Allow ModelCHeck to show components results directly in the first window / page
ModelCHECK is not optimal to use for assembly components checks and corrections.
Explanation : End-users are always complaining that modelcheck (interactive or regen) only shows results for top level assembly (not for its components) in the first result screen.
Example : Assembly "Test_Assembly.asm" is containing "Test_part.prt", both of them in my MC configuration should show "LAYER_MOVE" check as they both have layers with old names :
- When i launch Modelcheck interactif => All levels , the first screen only shows results for the main assembly (test_assembly.asm) :
- If i want to see/correct the components, i need to add 3 more clics (asm models => then choose the parts => then launch the MC correction), and this has to be done for all the components one by one (time consuming!) :
Can you please allow the possibility for choosing what to correct (Assembly AND/OR Components) directly in the first result page, this will save us a lot of time ! Smiley Happy
Thanks in advance
2 Comments
Aquamarine
Related PTC CASE : C14660617
Related PTC SRP : 8078802
Thanks in advance
Alexandrite
