Set datums cannot be displayed on drawings of parts when the set datums exists in the originating model of an inheritance feature. If GTOLs are created using these set datums in the part with the inheritance feature, the GTOL will display properly in the feature reference frame but the datums on the part cannot be displayed. Annotations work but set datums cannot be displayed. You also cannot create a set datum of the same name in the target model because creo recognizes the name is already in use.
