Soft/flexable parts, such as fabric covers, can take on different shapes when assembled. Currently, to display a simplified rep in an assembly, every layer of the model with the simplified part in it needs to have a simplified rep because the master rep always displays the master rep of all parts and assemblies in it.
Allowing the simplified rep to be set for the master rep when assembling parts into a model would allow the same model to be used for all variations of the final form.
