It is not currently possible to represent a variable ratio gear in mechanism. This is needed for defining motion of a continuously variable transmission (CVT). The functionality could be integrated into the gear definition by specifying a parameter which would be varied throughout a motion analysis. As an added enhancement for other non-static meshes, the gear ratio could be a user defined ratio with respect to angular position of one gear.
