The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Allow Window Selection while using the Project function within Sketch Mode.
0 Kudos
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
Aerospace and Defense.
Engineering Systems/Tools Analyst
Very large Creo Parametric user base.
2. What version of Creo Parametric are you currently running?
7.0.8.0 in Production
9.0.0.0 in Testing
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
Having to individually select curves for the Project function within Sketch mode is extremely tedious.  The system should be able to do the heavy lifting in this case by allowing Window Selection capabilities.
4. What is the use case for your organization?
Creating extrude features from very complex imported 2D geometry.
5. What business value would your suggestion represent for your organization?
Much easier workflow for creating intelligent 3D solids from legacy 2D data.
2 Comments
StephenW
23-Emerald II
Have you used the loop or the chain selection instead of the single? I guess it all depends on your initial data.
olivierlp
Community Manager
Thank you @gleonard3 for your idea. Based on the information you provided, we are acknowledging it as the Community management team. This is not a commitment from the Product team. Other users may comment and vote your idea up.
Do you have any reaction to @StephenW Comment?
