Would like the ability to add information from a PDF file onto a drawing sheet. Example a customer sends me a drawing in PDF format (they have no other file type). I do some design work that needs a drawing to represent the changes/design along with the customers provided information. If I could import the customers information into my drawing (as draft entities) then I only have one drawing file to manage.
