Allow a Paste Special on copied geometry go in as "Independent Geometry"
Would like to be able to copy geometry, surfaces, edges, etc.. Then paste special, which would create the geometry which was then non-dependent of the original geometry. This would allow the suppression / changing of the original geometry with still having the copied geometry for other uses.
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
