My company has thousands of parts that were not established with "material" specifications. When sectioning an assembly, the crosshatching always chooses what's on top of the listing for material, which is aluminum. 98% of out parts are steel, so the crosshatching always have to be changed. Add an option to allow a material to be the default crosshatch style.
