For some machines we have different cutting tool adapters.
So it is necessary to fill the field Cutting Tool Adapter in the options menu of milling sequences every time. (It´s because the postprocessors needs this information).
It would be very nice for our users when there is a possibility to set a default Cutting Tool Adapter or to use the adapter from the sequence before.
