When selecting edges to display stresses in a graph, it takes a long time to select all the edges.
It would be very helpfull if one could use the selection tools that is available in Creo Parametric in Creo Simulate as well.
ex select first edge, shift key, select the last edge.
or if one could use the copy and past funciton to select multiple edge and copy it into a feature, and then select the pasted feature of curves and select on it once to select the entire chain.
Currently you have to select the entities one by one for every graph you want to show in the results.
