When working on large assemblies, when assembling small components (likes screws). Sometimes the drag handle is located far from the part itsef, and this 3d handle is not dependant on the zoom, so the placement becomes difficult ...
Same thing can be noticed with cross sections 3D translation handle , its also not dependent on the zoom, sometimes difficult to use in large assemblies..
Can you create a setting that allows the 3D handles dependent on the zoom??
Thanks in advance
