Allow color of components to be set in assemblies
In Creo Elements/Pro, WF5, the ability to modify component colors has been removed except for top level components.  Also, the color set at assembly level changes the color of the component at the component level.
Please restore the ability to set the color of any component in an assembly, at the assembly level only (without changing the color at the component level).
3 Comments
vmcdaniel
2-Guest
I believe Creo Parametric 2.0 allows you to do this.
dhermosillo
Yay!  That was a fast resolution!  😉
PTCModerator
Emeritus
Status changed to: Archived
