Allow column width change in Compare Parts by Feature Info Window
The description column in the Information Window in Compare Parts by Feature is only 26 chars wide, while my information is much longer than that.  So I get the following:
DIMENSION VALUE: from 6.80
with no "TO" value.  This makes the information worthless.  I put a ticket in, and was told that there is no way to change the width of the column.  The log file that is saved is also truncated.
2 Comments
Dale_Rosema
DENNIS VAN ZEE
You may want to vote on your idea.....
olivierlp
Community Manager
Status changed to: Archived
