Allow comma key from number keyboard
When using German keyboard settings it is not possible to use the number keyboard because it generates a comma instead of a point as decimal delimiter. Creo always needs a point, the comma will be ignored. It should be possible to change the comma output to a point with a config.pro setting for example.
3 Comments
Just for my curiosity: how does other software using numbers (e.g. Excel, AutoCAD) handle this?  Is there a global Windows setting that applications should be following?
OliverHeins
Garnet
Usualy in Germany the cooma is the decimal delimiter and it will be set inside the Windows regional setting. In Case of Excel then the comma is the delimiter sign (maybe it reads out the regional Setting) and you can use the number keybord. But I am sure that it depends on the software. I am not used to AutoCAD because we have Creo Parametric in Use.
PTCModerator
Topaz I
