Allow different Creo View versions to be installed on the same computer
Allow different Creo View versions to be installed on the same computer.
Currently, if there is one version installed, the next version wants to upgrade and does not allow the user to change the installation path.
For evaluation of new versions, the user is forced to uninstall the first version, and install another version.  Then uninstall the new version and re-install the older version to return to it.
5 Comments
Have you tried to do a copy and paste of your current install to a new location before running the upgrade?
Aquamarine
Yes, that does not work.
Aquamarine
Now, with PTC throttling Creo View 3, this is more important than ever.  The Massive Assembly option holds companies data hostage in CV3, but 3D drawing viewing has been improved.  So now, we are forced to switch back and forth, uninstalling and reinstalling each depening if we want to bring up a large assembly with Creo View 2, or view a 3D drawing with Creo View 3.
Aquamarine
Stop throttling Creo View:
http://communities.ptc.com/ideas/3982
Community Manager
Status changed to: Archived
