Allow draft angle to be higher then 30 degrees
Make drafting posible with higher value then 30 degrees. It`s silly to use chamfer  sometimes to achive this because of 30 degree limit.
Also make this posible in extrude taper option.
5 Comments
lbai
Visitor
Information from GS in Creo 3.0,  update draft angle range to -89-89
DavorGranic
Alexandrite
TimHansen
Newbie
It would be better if they brought back the "add inner faces" with the sweep feature.  Solidworks can do 45°, but I've seen it make some pisss poor geometry in the processs.  Sweep is better!
PaulSagar
Garnet
This capability has been added in Creo 3.0
PTCModerator
Emeritus
