With the old Drawing note system, a mapkey can use the EDIT > PROPERTIES command to edit a note. However, with the new Creo 3 system, the only way to go back into a note is to click on it. That action can not be reproduced with a mapkey. Therefore, any changes to a note can not be done (unless you try running trail files).
