There are units within WindChill that can be specified for a BOM that Creo does not have. For instance, when working with WTParts in WindChill, you can specify to use a certain number of 'drops' of glue. However, in Creo there are no 'drops' in the units drop-down for a parameter value. If we would like to make this as smart as possible, we would like the units to match up with WindChill.
Thanks!
