Allow for user defined parameters in the .hol files without the need of FID
Currently if you add a user defined column in the .hol files the only way to get the parameter to show up in the hole note is to find out what the feature ID is and manually for every single hole note update it with something like &HELICOIL:FID_629 where 629 is the feature ID.
I want to be able to add a column called Helicoil (or any other parameter) in the .hol file and then to be able to call out &Helicoil in the note format without requiring that the user update every single note with :FID_
1 Comment
olivierlp
Community Manager
Status changed to: Archived
