The volume milling changes in Creo3 include a change in the way regions are manually ordered. The new list with the arrows is significantly slower and more cumbersome than the previous method of simply graphically selecting the regions in the order you want them cut. The time difference for large groups of regions is astronomical and to break these groups into small sets only increases time creating multiple sequences. Please consider including this previous functionality.
