Allow graphic selection of mill region order
The volume milling changes in Creo3 include a change in the way regions are manually ordered. The new list with the arrows is significantly slower and more cumbersome than the previous method of simply graphically selecting the regions in the order you want them cut. The time difference for large groups of regions is astronomical and to break these groups into small sets only increases time creating multiple sequences. Please consider including this previous functionality.
2 Comments
RaphMORIN
Oh yes, if only this could be quickly implemented. A while ago I had contact with support and talked to them about this, they told me they removed this functionality because it wasn't stable !!   ... Never had problem with this !!
For me it is really a step backward, so I'm still using old volume milling sequence (which in fact does the job very well) even if I'm working on Creo 3.0 M060 !!
olivierlp
Community Manager
Status changed to: Archived
