Allow graphing of measures against time step
0 Kudos
It is currently not possible to graph measures against time steps, for example in a large deformation analysis.  The results are all available in the .res file, but the formatting is clunky and requires either programming or a lengthy manual formatting exercise to use in Excel.
If multiple time step results exist, there should be an option in the results window to plot measures against time step (or equally against a load value or the time fraction, to give a linear graph axis even if the time steps are not equally spaced).
1 Comment
ToddKraft
Status changed to: Current Functionality
Thank you for the idea submission.  This is possible when providing manual time step information during analysis setup.
Todd Kraft
Creo Product Manager
