Currently, the only way to get Creo Schematic graphics into Creo Parametric is to export them as a .dxf.
However, when importing .dxf files they are always placed in the lower left corner of the format, and often overlap other geometry, tables, etc. And, once it is imported, it cannot be selected as a whole again since it is converted into text, sketches, hatches, etc. This makes it very difficult to select everything for changing colors, moving, scaling, etc.
It would be nice to place it outside of the drawing area to facilitate editing and then move it into place. (which also brings up how awful Creo's drafting tools are)
PTC please allow the initial placement of dxf somewhere other than the default.
Also, fix your abysmal drafting tools.
