See attached GIF. Currently when doing a drawing, you can select multiple dimensions and move them together. When working with 3D annotations in the model however, if you select multiple dimensions it only moves the last selected dimension. For complicated parts where multiple dimensions need to be created it can take large amounts of time to reposition all of the dimensions one by one as a new one is added.
