It would be handy to select multiple references using the find tool in sketcher. The example is when in sketcher and you need to add references, lets say points as the most practical example, you can add all the necessary points at one time. I think this could be limited to a few object types, but useful overall. Points, CSYS, Curves are the items I would like to see at a minimum.
