Allow orienting models in Replace -> Ref Table
When you replace a model by unrelated component, the software creates a temporary assembly to show the 2 components for reference paring. It is not corrently possible to orient one component in relation to the other. It would be handy if you could spin one around if the 2 components have similar geometry but different default coordinate systems.
2 Comments
JonathanHodgson
11-Garnet
I've only just discovered the Replace -> Ref Table, and it's fantastic - but this would make it better.
It could use the same Ctrl+Alt+mouse combination that works when adding a new component to an assembly.
PTCModerator
Emeritus
Status changed to: Archived
