Allow saving config.sup in any folders for Environment variable
Installing Creo under "Program Files" folder is important from a security point of view.However, only administrator edit "Program Files" folder. So, it is difficult to supply config.sup to client PCs.Therefore, it should set the folder where config.sup is saved to other than the "Common Files/text" folder.I wish being able to specify it with environment variables.
2 Comments
BenLoosli
23-Emerald II
Since IT does not do Creo installs, I put it on my E: drive in a PTC folder. I can still control security of the files, yet have full access to the config.* files in the text folder. We use a network location for our install, so I only have to install in one location and all usres have the latest build.
olivierlp
Community Manager
Status changed to: Archived
