Security Alert Log4j Security Vulnerability. Click here to know more.
Allow table cells to retain text formatting
Please vote on the existing ideas in the comments
As of Creo Parametric 3, M120, tables do not retain text formatting.  Which means that, even if the user formats the entire table, each time text is entered it will have to be formatted separately, significantly decreasing productivity.
PTC, please allow tables to retain formatting for entered text.
Reference:
Article - CS94103
Creo Parametric does not remember the Text Style set for a note or table cell in drawing mode. The Style Name in Text Style tab of Note Properties dialog is always shown as Default
https://www.ptc.com/en/support/article?n=CS94103
Table text settings
https://community.ptc.com/t5/System-Administration/Table-text-settings/m-p/481946
Is there no way to predefine the text format in tables?
https://community.ptc.com/t5/Creo-Modeling-Questions/Tables/m-p/99805
3 Comments
StephenWilliams
22-Sapphire III
I think this Idea is pretty much the same with 82 votes already.
https://community.ptc.com/t5/Creo-Parametric-Ideas/Text-Styles-and-Drawing-Tables-Worth-your-vote/id...
dgschaefer
And this one:
https://community.ptc.com/t5/Creo-Parametric-Ideas/A-row-added-to-a-table-should-adopt-the-text-styl...
And this one:
https://community.ptc.com/t5/Creo-Parametric-Ideas/Drawing-Table-Format/idi-p/453910
It's not a new Creo problem. It's been an issue, I believe, since I started using Proe in 1996.
dhermosillo
Argh. Frustrating that those didn't come up in my search.
