Allow tangent constraint to flip
Currently, when a user tries to assemble a bolt, insert, pin, etc. to a hole perpendicular to a cylindrical surface, the fastener or component is flipped the wrong way.  The "flip" button is grayed out so there is no way to easily fix the constraints except by using PTC's recommended workaround here: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS40703&art_lang=en&posno=1&q=FLIP%20TANGENT&source=search
PTC please add the ability to flip the tangent constraint so that components can be easily assembled correctly without having to use a wonky workaround.
4 Comments
RadovanMíček
(detail from the link) The functionality is planned to be introduced in Creo Parametric 5.0
vincecatlin
I heard it will be introduced in Creo Parametric 7
PTCModerator
Emeritus
ArnaudVandeVeer
Status changed to: Implementation In Progress
