In the drawing of Creo Parametric 7.0.0.0 it is not possible to create automatic balloons based on a table with a repeat region associated to a multibody part.
The buttons of the menu “Create Balloons”, in the Table tab, work only with a BOM table of an assembly.
It is of paramount importance to enable the use of automatic balloons with multibody tables, like the ones already added to the Quick Tables button.
