Allow the use of Windchill attributes in the Creo File > Open Dialog Box
Currently the File > Open dialog box only searches by filename in both the File name field and the Search field.
Please allow at least the search box to search on the Windchill Name and Number attributes.  Better yet, combine both fields and allow them to search on any Creo parameter/Windchill attribute.
6 Comments
lchelbelu
1-Newbie
One should be able to seach whatever columns are displayed in the open dialog box.  This is the same behavior as seaching in a table display from a browser.
dhermosillo
@Livius Because of the still poor integration between Windchill and Creo Parametric, some attributes are not available, such as the Windchill "Name".
DHLewis
The filter tools should allow filtering on whatever is shown in the column layout at the time.
dhermosillo
Unfortunately, the Windchill Name is not allowed as a column in Creo.
PTCModerator
Emeritus
Status changed to: Archived
Marcel_H
3-Visitor
Is there any solution on this?
Or why it was sent to archived?
