For current functionality, including &ptc_material_name in drawing note always displays as uppercase complex and cannot display combine uppercase and lowercase complex in a material name. For most mechanical standard, should like Steel instead of STEEL.
Workaround from https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS110551 is too complex
