As reported in post LINK , I would like to make an improvement for driven dimensions created as diameter (annotation menu).
I would like the driven dimensions created as diameter to be able to be reoriented with the same behavior as a diameter created from a sketch, that's to say. it can be reoriented from the FRONT annotation plane to the TOP plane for example. More precisely on a plane parallel to the axis of revolution.
See exemple below : reorientation of the two types of dimensions :
This methodology is useful when it is not possible to reuse the diameter dimension of the sketch.
Printscreen made with creo 7.0.5.0
