Actually it´s not possible zu zoom, pan or rotate while you are using the offset function in the sketch mode.
There ist often a problem to see the direction of you offset when you have to zoom to smal geometry and using the "Chain" select feature.
The idea is to allow such actions as zoom, pan or rotate.
