The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Allow use of parameters in GTOL additional text
Currently you can not use a parameter in the additional text fields of a GTOL.  If you try you will just get the text as you typed it and not the parameter value.  See attached image for an example.  This should work like notes, and virtually every other place within Creo.  My main focus for this request if for model annotations but the same could apply to drawing annotations.  This does not work in Creo 3 or 4.
6 Comments
MikeBrattoli
9-Granite
I am in full agreement with this proposal.  If the ability exists (in this case adding parameters within additional text/annotations) in other areas of Creo Parametric then it should exist in all similar areas/functions.  This is a product idea that should be enabled
hostroske
I also fully agree with this proposal. That's an absolute "must have" for Creo. Not sure why PTC doesn't support it so far. thought they fixed it, when they gave to opertunity to use parameter in annotation notes., but looks like they missed this one.
RyanG
This is a significant gap in functionality that must be addressed.
PTCModerator
Emeritus
zmiller
Thanks to everyone who has voted for this so far and helping getting the status changed to 'acknowledged'!
Mfridman
Status changed to: Under Consideration
