Angular Dimensions for Component Table Pattern
0 Kudos
1. Describe your environment:
Large Scale Machine Design in Green technologies Industry
2. What version of Creo Parametric are you currently running?
8.0
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
Trying to do whathttps://www.ptc.com/en/support/article/cs220240?language=en&posno=1&q=assembly%20component%20pattern...
says not being able to "works to specification"... then the specification is dumb, and must be updated to enable this.  Not all radial arrays are equally spaced, nor are they even increments of a specific angle value ( in which case one could de-select potential pattern members).  Sometimes components need to be placed at "clocking angle" locations.
4. What is the use case for your organization?
Designing our equipment
5. What business value would your suggestion represent for your organization?
No need for workarounds, CAD tool does what we need it to.
2 Comments
olivierlp
Community Manager
olivierlp
Community Manager
Hi @KeirPritchard  and welcome to the Community!
Thank you for your idea and the information provided.
