It should be able, to create centerlines in square and rectangle cutouts with only one click by 2D box.
Select cutout by 2D box and the center lines will be created, just like slot.
It would be helpful when you need to add the cutout center point dimension.
Now you’ve to create one horizontal and one vertical center line.
