In Annotation it should be possible to create isometric dimensions with correct orientation (see picture).
And with the real dimensions calculated automatically from the 3D.
yes - this is important
same idea in
http://communities.ptc.com/ideas/3087
correct link for same idea:
https://community.ptc.com/t5/Creo-Parametric-Ideas/Isometric-dimensioning-Creo-Elements-Direct-Model...
