In an annotation view it is possible to make all hidden lines either visible or invisible.
However, it is currently not possible to make all the hidden lines that are not within a cutaway visible and at the same time all the hidden lines that are within a cutaway invisible.
Workarounds:
- individually make unwanted hidden lines invisible
- make a separate partial view covering the area of the cutaway and define all hidden lines to be invisible in this view
