Annotation: it should be possible to filter the geometry to be copied
The function "Copy" in the menu "Geometry" in Annotation allows you to copy geometry which you can then paste to a work plane in Modeling.
Unfortunately it copies everything within the specified box. This means that the geometry that is not required must be deleted from the work plane afterwards.
It should be made possible to filter the geometry that is to be copied so that for example center lines, hidden lines and tangential lines are not copied.
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
