Currently when you have several combined states and appearances (colors) in each one of these, only the appearance activated during the STEP AP242 export is saved.
So when you open the STEP AP242 there is the same appearance (the one activated during the export) in each combined state.
Creo should export correctly appearances on combined states with a STEP AP242 export.
