Today when using CFD in Creo environment it is very easy to get the pressure on a surface, based on the CFD analysis result.
what currently missing is the ability to have also the resulting FORCE on the surface due to the pressure.
Today the engineer take the pressure result and calculated the force in different ways ( hand calculation, Matcad and others ).
Having this automatically calculated will save significant time to the engineer and will result in much accurate result.
this functionally exist in any other CFD softwares ( include the ones which inferior to Creo CFD ).
