Architectural Sheet Size Drawing Format Options
I would like to see if any other users have this need.
We work in a work where we deal with a lot of Architects and they all use Architectural Sheet Sizes.
When we go to create our Drawing Formats, we have to use variable formats and input the Sheet Dimensions (i.e. Arch_C - 24"x18"). In our title blocks we want to use the &format parameter to automatically show the sheet size. If you use the ansi sheet sizes it works great. However, if you use the variable formats it shows the dims and not C or Arch_C it shows 24" x 18".
There is not current way to automate this since Creo does not have the Architectural sheet sizes in the default list nor do drawings have the ability to store relations on their own without a model.
We would like to have the Architectural Sheet sizes added to Creo.
Also, like the idea about the  Architectural Scale options to be added. Architectural Scale
2 Comments
RaphaelCNascime
1-Newbie
Thanks for creating this idea, Andy.
Let's see how many others in the community could benefit from adding architectural sizes to the list of standard drawing sizes.
I'll put this idea to Under Consideration to show I've reviewed it, but voting will be kept open so others can still add their votes.
olivierlp
Community Manager
Status changed to: Archived
