This is a product idea conversion of case C13362807. In Creo, dimension arrows are sometime shown outside the witness lines and sometime inside. Currently there is no way to determine the display type of arrows (arrows are placed inside or outside the witness line) for a given dimension; no API support is available for this information in Pro/TOOLKIT. Without this information, Creo PMI can not be represented correctly in other derived formats for downstream usage. This gap results in wrong visual representation of PMI, therefore we need support for this information in Pro/TOOLKIT.
