Assembly Bill of Materials to be able to use component level parameters
0 Kudos
Article: https://www.ptc.com/en/support/article/CS170420 says that the Assembly Tools>Bill of Materials can't be customized with component level parameters. We would like to include LINENUMBER, which we use to transmit BOM linenumber data to/from Windchill via a component level parameter.
Thanks!
2 Comments
MichaelC.Martin
Apologies for missing something obvious but I can already report component parameters in a repeat region.  For Line numbers I use &asm.mbr.cparam.LINENUMBER.  The value is set in a component parameter (linenumber) at the ASM-level  created for each component in the ASM.
jwagh
Michael,
Correct. But engineers may not have a drawing open, or ready. They want to quickly view and export the bom. By having the line number available, it can be done quickly without the use of a drawing.
