I'm using Creo Parametric 2.0 M120.
In a medium-large assembly (5800 parts) if Smooth_Line option is enabled, it takes a long time to make an offset cross-section (+/- 5 minuts).
If Smooth_Line option is disabled the same cross-section can be made in less then 1 minute.
I have made tests in some Hardware scenarios, the worst machine configuration was an "Intel Core I5 - 4G RAM – 1G graphic card" and the best machine was an "Intel Core I7 - 32G of RAM – 2G graphic card", in both machines the results was similar.
Its important to me to work with Smooth_Line enabled but, it need to be faster.
