Scenario: There are couple of options to create Datum Targets in MBD model. But when we need to add or create multiple datum targets at same location then we can create them one after another. While doing that there will be multiple leader lines for multiple datum targets. This will create confusion while checking the model.
Issue: We can add one datum target with leader line and all other without leader line. But the targets without leader line we need to specify the location. So for doing this we need to attach all datum targets manually and this will be helpful for reducing the confusion.
But all those targets without leader lines are movable and we can not restrict their movement.
Requirement: So as like drawing file as functionality of Relate To Object, Can we have same functionality in MBD model so that all other datum targets can relate to one with leader line.
