The HTML report that is output from Creo Elements\Direct Design Advisor (FEA) can only (by default) display images in the report via VRML viewer.
In Part Library Icon, a real time screen can be created as a thumbnail for an Icon. I would like to suggest a similar feature here. This allows the user to position the model in a preferable position and create a simple image - although, preferably better integrated into the FEA report.
I appreciate that the HTML code in the document.html can be edited and pre-determined image be defined in the code, but this is clunky. Minimum expectation of an FEA report is that it can display an image by default.
Additionally, VRML is no longer supported in Chrome. Probably the most popular web browser in use.
PTC Details:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS240432
